Plumber or electrician to replace new timer switch Unvented cylinder
View the thread, titled "Plumber or electrician to replace new timer switch Unvented cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Replace the current E7 Newlec Economy control to a mechanical 24 hour timer switch for unvented cylinder water heater, may I know if I ask plumber or electrician to do this job.
Because Newlec Economy controller can heat up water once a day in midnight .I would require constant hot water in different time slot per day.
How to Make sure that Timer switch wire connects with bottom element instead of top element ( boost). As the boost can heat up 1/3 of tank water only.
Appreciate for any help or guidance. Thank you.
Reply to the thread, titled "Plumber or electrician to replace new timer switch Unvented cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
Jan2238,
ShaunCorbs,
