M
Mike-H
15mm chrome yorkshire kuterlite compression elbow x16
15mm BOSS chrome isolation valve x17
15mm non return valve x2
15mm yorkshire tectite 316 pro elbow x12
15mm yorkshire tectite 316 pro equal tee x9
15mm yorkshire kuterlite compression equal tee x5
1/2 bsp drain off valve x2
15mm tectite push fit drain off x5
15mm tectite 316 pro bent tap connector x3
15mm tectite 316 pro straight tap connector x4
15mm straight compression couplings x2
15mmx10mm compression reducer x6
15mmx1/2 connector x6
15mm hose tap & backplate x1
15mm yorkshire kuterlite chrome backplate x1
1/2 auto air vent
15mm tectite 316 pro flexible hose x3
22mm tank connector x1
22mmx15mm tectite 316 pro reducers x9
22mm gate valve x1
22mm chrome yorkshire kuterlite compression coupling x2
22mm yorkshire kuterlite chrome compression elbow x5
22mm tectite 316 pro elbow x6
22mm chrome BOSS isolation valve x3
22mm BOSS isolation valve x9
22mmx22mmx15mm tee x8
1/2 gas lever valve x1
3/4 gas lever valve x1
22mm tectite pro 316 equal tee x3
22mm stop tap x1
28mm tectite 316 pro elbow x9
28mm tectite 316 pro equal tee x4
28mm tectite 316 pro stop ends x26
worth quite a bit open to offers if anyones interested. got a pic i can email of all the fittings, there all new just the file is too big to upload on here.
Weigh them and i'll give you £2.60 a kilo
tamz- we all know your a millionnaire after all your years plumbing :tounge_smile: so 2.60 a kilo seems a low offer (even for a scotsman who we all know are tighter than two coats of paint!)
my offer as a generous englishman is 2.63 per/kg :wink:
time to make my getaway ....:boat::15::leaving:
Reactions: 2 people
