Plumbing help in kitchen needed - can't turn water back on!
View the thread, titled "Plumbing help in kitchen needed - can't turn water back on!" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi there,
I've recently done the plumbing in my newly renovated bathroom and thought I'd have a go at the renovated kitchen. All was going well until I managed to move a 15mm cold water pipe and cause the stopcock to drip! I managed to stop the drip but am nervous about continuing to experiment! If I mess up the stopcock I'm seriously messed up. I really didn't want to call a plumber in if possible as I'm trying to learn from my mistakes
So, my gas man had encouraged me to use quick fit plumbing fittings and I wanted to simply add a 15mm equal tee to the cold water line for my new dishwasher. I bought the Speedfit part and when I tried to fit it...things went downhill.
i carefully measured where to cut the pipe and tried to get both ends onto the pipe and then screw it back together...but without success.
I'm sure I've made a massive mess...and I now have no water because I can't put it back together!
Please see the attached photo and advise if you can.
Thanks a lot,
Taryn
(I thought about adding a few elbows which could work but would be completely bizarre and messy I'm sure).
So interesting....I'm a recent convert to the joys of plumbing and am trying to learn all I can. That makes sense with compression fittings as I wondered why most of them didn't have tape. Can you use too much tape? It seems that sometimes I have put too much and it doesn't screw in that much. If it doesn't leak I guess that's okay! Also, is it standard practice to tape the olive rather than the screw bit? Thanks!
I tape every olive on my compression fittings. No point having a leak for the sake of it! It has saved me many many times in the past.
I`m with you here, taking into account mine are all old joints which I`ve undone I always add 2 wraps of PTFE around the olive for peace of mind, don`t wanna have to go back because of a slight weep, also find it less messy than a paste.
When the fitting is in an awkward spot and you cant be bothered to struggle getting tape round the olive, you immediately regret it when you turn the water on lol! A TINY drip that doesn't ever stop..
With a little practise you can tear a 2" strip off the reel if it makes it easier to get it on the olive.
Some fittings are nowhere near as good as they used to be and guess you`ve never taken an old joint apart and looked at the mating face`s then.
Indeed I have. I always put a bit of jet on the mating faces. Like i say personal preference whatever works for the individual
What I ask myself is: 'Which of the two is good for my health?' PTFE is just that, a thread, whereas a paste of any sort will let traces filter into my system now & again. I know which one I will prefer!! The PTFE tape
Reply to the thread, titled "Plumbing help in kitchen needed - can't turn water back on!" which is posted in Bathroom Advice on Plumbers Forums.
Taryn Hauritz,
village idiot,
