View the thread, titled "Poor flame when internal cover fitted on Worcester junior 28i" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
Graeme28
Hi, this is my first time on a forum so hopefully will get to the bottom of this. I'll do my best to keep this straight to the point;
1. Boiler kept locking out after about 30 mins of central heating.
2. About 4 weeks later boiler cut out and would not reset.
3. Found APS hose connections melted and blocked.
4. Drilled out hose connections as have to wait till tomorrow for new switch to arrive.
5. Boiler runs fine with internal cover off.
6. Internal cover refitted flame turns yellow and cuts out.
7. Removed fan and checked for freeness and also checked Venturi for blockages, both appear ok.
8. Removed flue and inspected, again appears ok.
9. Refitted everything and same fault occurs?
Could the fan be running too slow to remove gasses even though it is free to turn?
Any help will greatly appreciated.
You will need to confirm your gsr status to get this advice at which point it will be answered in the private forum.
raise your post count to 10 and pm gas man or redsaw.
request thread closed please mods.
closed , sorry Graeme28 as a gsr am sure youll understand the dangers of giving advice on the open forum which could be read by dangerous DIY`ers
Reply to the thread, titled "Poor flame when internal cover fitted on Worcester junior 28i" which is posted in UK Plumbers Forums on Plumbers Forums.
