Whilst I've had plenty of scaled plates causing poor hot water performance I've never had scale on the dhw side causing boiler overheating, as the system side would be clear and modulate down based on flow and return thermistors.
Just my experience though.
I have had them before when the plate to plate is really scaled up and it makes all sorts of kettling noises with the boiler shutting down. It's not like that though with this one. Still not sure what to do next.
On hot water mode the modulation is carried out by the dhw thermistor. The primary thermistors are basically high limit stats and should cut the boiler out before it over heats.
Sorry I disagree.
The best route for the customer is to diagnose and fix it yourself.
All the manufacturers care about Worcester especially is selling boilers they re not worried about the customers or the installers.
@Millsy 82. Disagree all you like. Says a lot. If the cost of me repairing is more expensive then a Worcester fix. The options are new boiler or Worcester fix. For example, there is no way a normal engineer can fit a main heat exchanger in a Junior for less then a Worcester fix priced repair.
And mine??
I pretty much said.
Dont give the work to the manufacturers. They dont give it back. Yes if you install 100 Worcestershire a year they will look after you but otherwise they couldn't care less if you get work or not.
Better money going into your pocket than theres.
As for if you cant diagnose it. Speak to tech it's free and if you know what to ask which has been said on this thread you should get to the answer.
Will Worcester pay your mortgage? How about baxi? Vaillant? No none of them will YOU need to earn money as well.
I do and the same customers keep coming back even after a fixed price repair because I have saved them money.
I pretty much said.
I agree it can be a good move to call in the manufacturer for a fix priced repair. I have done it my self but only when I know with out a doubt it'll cost more for me to fix it. It could be very embarrassing if the fault doesn't cost a lot to repair!
With regards to calling Worcester or any other manufacturers it can be hit and miss with them. They might have the answers on a screen in front of them but I'd say not many of them have hands on experience. I might be wrong. It's easy for them to say replace this and that but this and that can cost 100's!
Back to my question though..is there more than 1 DHW thermistor??
What about when your customers want an install do you say Go with Joe blogs plumbing as he will fit you a boiler for £100 where as I will charge you £500 so you save them money then.
A
UK Plumbers Forums
Deleted member 120897
