Update so far;
Sent an email to the private building inspector to basically have some hard evidence that I have informed him of our concerns regarding proximity of window to flue. Also to confirm that I was right in believing that he was going to pass the extension off without any concerns that there was any breach of regulations, being either health and safety or building, and no danger to life...........he passed the query onto the top dog.
In the meantime Ideal have replied by email,to the photos sent, to comment that from the pictures the window appears to have been fitted to close to the flue....... email forwarded to BI.
It’ll be interesting to see if building inspector communicates in any way shape or form with gas safe......
Reactions: Burger
Hi, we’ve nearly got an answer to this problem and will update as soon as verified, however just a question for you all.......if able to reach the flue how many of you would work on the boiler if the velux window was permanently fixed?
I don’t think that the regulations GS(IU)R differentiate whether or not the window can be opened. The flue terminal must be a minimum distance away from the window.
I always believed it to be an openable window where the minimum measurement applied
I dont think thats correct
What if someone gets the window changed to an opening window?
I think someone died beacuse of similar and a gas fitter went to prison
Reactions: ShaunCorbs
If someone gets the window changed then it's up to whoever changes the window to seek professional advise to make sure what they are doing is safe.
But if the homeowner and window fitter are not gas safe and dont see the potential problem
But ignorance of the homeowner/windowfitter is not the engineers fault. Regs regarding flue positions relates to openings, a solid window with no trickle vents is not classed as an opening. Saying the homeowner may change the window to openable in the future is no different to saying the homeowner may put a conservatory there in future.
And how many conservatories do you see encroaching on flues or with opening windows too close
I was always told an opening means opening in the fabric of the building not an opening window
Reactions: SJB58
Scott, what do you think an opening window is?
[automerge]1565727279[/automerge]
That’s like saying the flue is near a plain brick wall, but in the future someone puts a door in.
That would involve building control who should flag it up
And how many people actually inform BC of intentional work?
[automerge]1565727703[/automerge]
My take on an opening into the fabric into the building is exactly as it says.... a passage from external into internal airspace, whether that’s into habitual rooms or not.
Seems we are both right, to clarify I looked through part J of the building regs, it does state than an opening is referred to as, e.g. openable window, air bricks, vents etc. But it also states that no flue outlet shall be positioned within 150mm of an opening in the fabric of the building e.g a window frame. So 300mm for openable window, and 150mm for a fixed window.
Reactions: Scott_D
Seems we are both right, to clarify I looked through part J of the building regs, it does state than an opening is referred to as an opening, e.g. openable window, air bricks, vents etc. But it also states that no flue outlet shall be positioned within 150mm of an opening in the fabric of the building e.g a window frame. So 300mm for openable window, and 150mm for a fixed window.
Good to get some clarification
Reactions: Aire
