R
ramduck
hi guys can i pick your brains? i have a potterton gold combi.
last night the boiler tripped the electric. i found some heating system water leaking from the diverter value- motor unit and assembly.
when i removed the motor unit this morning i found where it fixed full of water which had made it way to the multi-pin plug which i think s made the short. i dry everything out and re fitted, but as soon as i started the boiler i had small water leakage backat the top of the valve assembly.
i didn`t find any washers or o-rings round the top of the valve assembly or bottom of motor unit.
are they missing or will i need a new valve assembly?
thanks guys
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
