buckley plumb
had a weird one today when switched on it would go straight to bottom 2 lights constantly on . flame failure and power on lights on. when reset it would go straight to this again within 1 sec. I did a master reset and it worked as normal - what normaly causes these to need to be master reset .
what is the flue run? standard or not?
standard mate - working fine now since master reset - just puzzled me how only master reset would cure it.normal reset boiler lights come on instantly after letting go of rest - even turning power off at spur and back on gave instant 2 lights no pump or fan.
What is a master reset???
need to do it on fitting new board - I always forget how when I need to do it .from memory - turn boiler on then turn knob to reset and let go then to reset and let go then to reset and hold for 45 sec- 60 sec the let go . mark will correct me if I am wrong
UK Plumbers Forums
Deleted member 120897
