M
MDS PLUMBING
Dear all.
I have a promax 15he which I replaced the ignition PCB. Now lights fine but seems to cut out on the stat after 10 minutes and does not relight. Pump is running, SL is live, Pump has L feed and rads are starting to warm upstairs and down. When burner extinguishes there is still a pump feed but temperature in the circuit is no way near hot enough for stat to cut out.
I know these have sensitive flow switches but its full of water.
Any advice appreciated.
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
