Oct 30, 2019
DIY or Homeowner
We have a Rayburn 600k (cooker only) which fails to ignite. Having turned it on, it cut out and went completely dead, no lights on the panel or anything. I checked the fuse In the plug, found it had failed and replaced it. Now it just fails to ignite. In turning the temperature dial, the blower starts, but there then no buzz from the igniter which usually precedes the whoosh when the burner starts. My thinking is that there's a fault with the ignition circuit which initially blew the fuse, but now just doesn't work. I'm not sure what the usual suspects could be, nor how to go about diagnosis. Any ideas or advice gratefully received....
Thanks for that - I tried a new transformer (£25), and that seemed to sort the problem. Control box still seems to be working OK.
