fubar1000
199
48
28
Thurrock/ Essex
Thinking of buying the new MagnaCleanse, but as it's a lot of money I would just like to know what you's guy's are using?
& what you's think of the new magnacleanse machine?
The MangaCleanse is a lot cheaper, has a lot less to go wrong & seems a very good idea, but I just can't see it being better than a proper powerflush machine.
Any input would be good thanks people
A proper job is to use a powerflush machine with a magnacleanse/ Kamco filter.
Lots of money but so is the job you are doing.
power flush machine and magnetic filter used together, so buy them both.🙂
the magnetic filter on its own wont remove a half of what a machine will imo. I think using a large filter when you do a chemical/mains flush on a boiler change is a good idea, but if the system needs more than a mains flush then you need to use a machine. Care should be taken when selling a filter flush, some engineers seem to tell there customers they are getting a powerflush which is a shame and why they come onto the forum asking if they got what they paid for.
Reactions: 2 people
Used both and either work well if used properly, magnaclense you need to vibrate the rads into oblivion . A Magnaflush isn't same as power flush same as a power flush won't provide ongoing water quality management. But neither can be done in sixty seconds! Sweaty job system cleansing in summer especially if three floors! Nice in winter though!
Used to use a magnacleanse. They are good but only relly on system pump for flow so if you have a blockage or a slow system you will wish you brought a flush machine.
I have since brought a Kamco machine with a magnet attachment and I never use the magnacleanse anymore. Plus the magnacleanse is annoying to set up if they dont already have a magnaclean fitted.
Ive been using the magncleanse attached to my powerflush machine for about 5 years now, with the two massive magnets there is no need to fill and dump each rad to get rid of the black sludge, you can see the pipes getting clearer and clearer untill it passes turbidity.
Then just do a whole system dump and refill
Reactions: 2 people
Ever left a responsible adult in charge ...... Gone to shop and returned to a flood? A friend (not me) left 2nd year on a flush, came back to a partially flooded plant room come steam room! Thankfully not in a house. Quick release on mag came off, due to entanglement of leg! 75mm water in room about 6m square.
The 1st time I used my Magnacleanse ( without Powerflush machine).
I had the magnacleanse outside the airing cupboard, boiler running and a hose pipe on the return on the boiler, with filling loop turned on.
All was going well for about 1/2 an hour, mobile rang and I had a 10 min chat with a customer, call ended and I went back indoors.
All I could see was the 25mm hose snaking at the top of the landing drenching the whole area in dirty black water using the boiler pump and fresh mains water for maximum pressure !!!!!!
I had to totally redecorate the hall stairs and landing and replace the carpets.
Soon after 30 mtrs of 25mm hose was purchased and the Powerflush machine and magnacleanse are never used indoors again.
Adey sent me a new set of clips!
Reactions: 2 people
Norstrom pro flush with built in heater and external magnets for me. Not the cheapest but i get on well with it and had some good results on badly sludged systems. You couldn't do that with a magnacleanse really
UK Plumbers Forums
Deleted member 120897
