Hi Everyone,
to cut a long story short i have a customer that has had problems with pressure in their heating system. i have got the system to stop dropping pressure then they spotted a small leak from a manual air vent on cylinder flow to coil.
I replaced this with a auto air vent and left it open to remove air, but the system just keeps loosing pressure but not water from valve.
I have closed this up and now the pressure holds. In my theory there must be a small leak on negative side of pump which is drawing air in the system and this is being lost through AAV?
Could there be another explanation to why system pressure keeps dropping when AAV open, it is dropping from 1.5bar - 0 within 1 hour. As said earlier when AAV is closed pressure stops dropping.
Also how can i trace where exactly the air is being drawn into the system? Would bottle of leak sealer fix the problem?
Appreciate all your comments.
