T
tackleburger
Here's a good example of being undercut.
New combi boiler 8 rads all pretty big ones 1000s & 1200s K2s. Existing system Linea 28 with 7 rads all 2400 long and 2000 long single panels. I know it's strange but thats what's there, must have been a job lot. One rad to be moved as well. So did the heat loss calcs and sizes are about right.
I went in at £3400 with VAT to supply a Ecotech 837 flue two extensions and a bend, condensate pump upgrade gas supply curent is 15mm running 5 meters after the cooker and fire off a 22. Probably 3 days for me and a second year apprentice. Loads of boards to lift and an awkward attic gas and condensate run.
I was undercut by £800 when I rang him to "discuss" the quote. Turns out the other quote is for a Procombi 29KW same rads no upgrade to gas (which is required for any combi).
I got the job but had to haggle a bit and only because the guy had been told about Vaillants from a work colleague and I had measured the rooms, took a pressure and flow test and asked if he was adding anymore water outles in the future. He told me he wants an additional shower.
But to the unsuspecting I would be dear and he'd have got a worse boiler than he took out.
