Problem encountered in connection of 2 water tanks with different volume
View the thread, titled "Problem encountered in connection of 2 water tanks with different volume" which is posted in Bathroom Advice on UK Plumbers Forums.
darren72
Hi All,
I have a doubt on the water level balancing between 2 water tank of different volume which i sincerely hope that you can enlighten me on that.
In view of additional water demand in one of my upgrading projects, I have to increase the effective water storage capacity of the existing water tank from 84 m3 to 136 m3. Current tank size is 10m(L) x 4m(W) x 3m(H) with center partition. However, in view that the operation requirement of the building, existing water tank need to be in operation for 24/7. Hence, a new tank is to added on beside the existing tank to meet the new water demand.
A tank size of 5m(L) x 5m(W) x 3m(H) will be sufficient to meet the new effective water storage capacity.
My question are as follows:
a. If the 2 tanks are linked up by a balancing pipe , will this cause overflow at the smaller tank? If yes, how to mitigate this problem as both tank will need to be connected to a set of water pumps before going out to the fittings.
b. Alternatively, if the tanks are not linked up, will there be any problem if the outgoing pipes from the 2 tanks be linked up together before connection to the pumps.
Your help is very much appreciated.
Reply to the thread, titled "Problem encountered in connection of 2 water tanks with different volume" which is posted in Bathroom Advice on Plumbers Forums.
darren72,
PlumbBobBob,
