Problem with Vaillant eco tec boiler
View the thread, titled "Problem with Vaillant eco tec boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
My 10 year old Vaillant Eco Tec Boiler pump/fan occasionally turns on for 10 secs when the cold water supply is turned off at the tap or toilet after use. If the tap is turned off slowly, it doesn't happen. Any suggestions please?
Needs a non return valve and a shock arrestor fitting as the shock wave (from shutting the tap) is triggering the flow switch
Sorry but just seen your reply and thanks for it and your interest. Where should these be fitted near the boiler or incoming supply? Thanks again
You possibly have a dead leg on the hot water system somewhere. Getting rid of that would more than likely stop the problem.
Reply to the thread, titled "Problem with Vaillant eco tec boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
alanem,
alanem,
