T
taxes
Hi everyone,
I am having a lousy experience with Fluidmaster and wondered if anyone else has.
I am fitting 5 toilets in a new house. 4 will be concealed cistern. I purchased one concealed cistern from B and Q on line to see if they were any good. The cistern itself is cheap plastic but that's OK as it won't be seen and there will be extra soundproofing. At first B & Q sent the wrong one (visible) but the next one came with Fluidmaster fittings.. Good, I thought. However, when fitted the unit produced a loud water hammer which had me checking every other outlet in the house for air. Eventually I phoned Fluidmaster to see it it was a known problem - and it was! Apparently, all concealed cistern valves they supply to B & Q have this fault! They do have a fixing kit but don't supply it to B & Q! They sent me one for free but it did not totally cure the problem. They then sent me a new inlet valve which did cure it. However, I then noticed a definite "Clunk" when the cistern finished emptying (both short and long flushes) and was told by one of there engineers that ALL duo flush valves made a noise on re-seating. I told him that I had other duo flush toilets which did not clunk and he dismissed my comment saying my hearing was probably not good enough the hear them. I have since checked out two other non fluidmaster duo flush toilets and there is NO clunk.
I am very disappointed as Internet comments all seem to praise fluidmaster but I have found both the products and the support totally unreliable. One other point, the first fluidmaster duo flush valve did not work properly (small flush adjustment not working) but a replacement did work.
Sorry for my first post to be a moan but can anyone suggest a reasonably priced duo flush that does not have the above problems?
Thank you.
the water hammer is caused by the very cheap plastic b&q cistern having no strength to it. The cistern flexes as the ball valve shuts snd causes a wave. This can be cured by using the flow restrictor supplied in the fluidmaster ball valve kit. ( probably not supplied in the b&q set)
pretty much all flush valves shut with a thud, but I guess yours is noisier because of the wobbly cistern. You could try coating with expanding foam to make it more rigid?
i would just return the cistern and buy a good quality one like Grohe or geberit.
I've never had much of a problem with fluidmaster fill valves to be honest, hate cheap crap concealed cisterns though.......
I personally don't fit anything other then fluid master and am yet to have a problem. A lot of things sold to b & q aren't always the quality that is purchased from a plumbers merchants or tool retailer.
All flush valves do shut with a clunk, and trust me I have fitted everything from V&B to B&Q. As Chalked has said above, all depends on quality of plastic used on cistern and if there is any polystyrene (soundproofing) on the cistern.
Fluidmaster are generally pretty good.
Many thanks for the prompt replies. I will check all the points made on Monday. Looks like I may have been unlucky. The cisterns, although plastic, are enclosed and secured to a 1000 mm square18 mm plywood panel and just don't move.. However, I DO have two duo flush cisterns with absolutely no clunk. They are in another house so I will check their make.
Thanks.
Off the subject here but I read recently that zannusi supply washing machines to john lewis.
JL offer an extra years warranty on these machines and zannusi supply better quality parts inside them to help prevent faults. Just what I read.
Sounds like some companies can stipulate the quality of certain goods so they can supply for a certain price. No doubt it happens all over and the customer is non the wiser. I can't imagine its the case with something as small as a flush valve mind!
Yes to both. It did improve it slightly. I have also turned an isolating valve down. I know that does not technically reduce the pressure but it does quieten the fill slightly.
