Radiator on studs on top of bricks
View the thread, titled "Radiator on studs on top of bricks" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I need to hang a radiator (160cm wide, 50cm high, total weight around 35kg) via two brackets to a plasterboard wall.
The wall is external, so that it has studs (about 12mm deep and 50mm wide) behind the plasterboard and then bricks behind the studs.
I am lucky enough to have studs in correspondence of my brackets.
However, I was wondering whether the 12mm depth of the studs would be enough for the screws to bite, or if I should reach to the bricks behind the studs and fix the brackets to them.
If I can use the studs, how do I make sure that the screws go through the whole 12mm, given that this will be prevented by them hitting the bricks?
Thanks.
I wouldn't know. Perhaps check with the manufacturer of your radiator. I have a similar size radiator on my bathroom plasterboard wall with feet. The brackets go through the plasterboard and hold it in place and the feet take the weight, although I didn't install it but closely watched the firm that installed my ASHP.
There not that expensive around £21 for 24 for the 100mm version
I need way less than 24, and probably my local shop won't sell them. I just found somebody on this forum (funny thing, in a thread involving you @ShaunCorbs 🙂) simulating a poorman's version of the corefix by using standard wall plugs inside the brick, and then a suitable length of copper pipe to make up the difference as to not crush the plasterboard. I think a nut recessed into the plasterboard could work to a similar effect. Any feedback on this option?
Works out cheaper than buying a 12 pack etc
Yep only alteration is I would use steel conduit and two washers bracket side as it won’t compress but as your distance isn’t that much and the extra labour upto you either is acceptable
This is being really over-thought. Mark up an aesthetically optimal position and use 7mm holes and short lengths of copper tube as mentioned above, nothing's going to crack, the copper tube against the brick and rad brackets will do the job of holding it in place. I've got a rad about that size in my bedroom held up by 4 pigs tails, been there 15 years.
Thanks. Yes, I overthink, especially when doing something new. Better safe than sorry 🙂
Reply to the thread, titled "Radiator on studs on top of bricks" which is posted in UK Plumbers Forums on Plumbers Forums.
phloaw,
phloaw,
