you need this from toolstation
http://www.toolstation.com/shop/Hea...762/Angled+Radiator+Valve+Drain+Off+CP/p40214
I have now been to both the main plumbing merchants in Abingdon (Grahams and Plumb Centre) and nobody in either had ever seen a Lockshield valve with drain with a 1" thread to the radiator. The guy in the Plumb Centre said he'd worked there for 25 years and never seen one even though my radiator is only 15 years old.
How come I can then walk into Screwfix of all places and buy one over the counter as recommended by you guys on the forum? It seems to be a standard size for Screwfix but to nobody else in the industry?
It doesn't matter what the technical description for the valve is, I took the original one into the plumbing merchants and they said they had never seen one before with that sized thread on the radiator outlet!!
I didn't say it was a '1" lockshield with drain off '. In fact it is a 10mm radiator valve with drain off which can be configured either as a lockshield or a manual valve as described on the packaging but it has a 1" thread on the radiator connection.Because it's not a 1" lockshield with drain off :banghead:
But that's not the rad connection, it's the connection on the Union
My radiator came with the tail/unions already in place and that is what I was trying to connect a new valve to. What I was trying to understand is what are considered standard union thread sizes for these types of valve and why Screwfix do a 1" threaded connection to the union but proper plumbing merchants don't?
Fortunately, I've now got a replacement valve from Screwfix and so the problem is solved!
it is called 3/4" not 1" that's why
I bought part 36552 from Screwfix. As said, I took the original valve into the 2 x plumbing merchants and neither had a size that matched. I'm going back to Screwfix tomorrow to get another valve for the other end of the radiator without the drain.
