rads upstairs not working
View the thread, titled "rads upstairs not working" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
B
bedspoolplayer
hi did a conversion remove b/boiler fitted combi as agreed with my mates customer he is g/safe the hot water working fine all the downstairs rads working ok there are four rads upstairs which only one is working all rads already have trv on about four years old am not sure if they are flow reverse ones or not but the other rads are not heating up just luke warm is it possible they used onje pipe system upstairs or not the guy said they were working before but never seen system working any ideals welcome many thanks inadvance
hi removed the trv heads pins seems free but as said earlier not sure if there are flow reverseable the cust said about four years old many thanks
try tapping on the pins with your adjustable spanner fairly hard lots of times quickly , this should free upp any stuck seats , it does not matter about the flow at this time as all that will happen is you will get a chatter on closing , do,nt lift the pins just tap on them
Reply to the thread, titled "rads upstairs not working" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
bedspoolplayer,
bedspoolplayer,
