W
wilmslowwhite
My problem is that this flexi-connector is about 150-200mm short of the back of the pan. Is there anyway I can connect the WC to this flex connector? Joining another connector to this pan connector? Or is there a flexible pipe that I could attach?
This flexi-connector fully extends to 570mm but it still leaves me about 150 short.
The flexi is connected to a 92degree bend. There isn't enough room below the floor boards to add another 110 pipe to the bend. Half of the bend is covered by the tile which is why I've used the flexi. There isn't enough room to move the bend closer to the stack and then come up with a solid pipe as there are a number of CH pipes that would need moving.
The toilet is in position to be boxed in. I can't move it closer to the flexi as those pipes at the back of the picture will be boxed in.
As always your expertise will be greatly appreciated.
