I recently have had a water softener installed in my property. Due to the house being a new build the engineer wasn't able to install a hard water tap in our kitchen (without the undertaking of huge, costly works).
In the cupboard, there is a water valve that can be turned to switch the whole house's water supply from soft water to hard water (bypassing the water softener unit). The cupboard is a bit of a pain to get into and the valve is right up the back of it.
However, I was wondering if anyone knows a solution of getting a mechanical/remote controlled valve, so that I could simply flick a switch in the kitchen and the valve would change in the cupboard?
I have looked up possible solutions, but I am not a plumber, so not sure if I am finding the right things or not - which I don't seem to be finding. Basically, I see it as replacing the mentioned valve with a mechanical valve and then some sort of remote (not wired) switch to flick. If it has to be wired, then I would do that too as that would just be a case of running trunking around the rooms until it arrives at the valve.
Please do let me know if you know of any solutions to this. I am happy to share pictures of the valve too, for an easier understanding.
