Removing a toilet seat
View the thread, titled "Removing a toilet seat" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
For the life of me I can't work out how to remove the attached. Any advice? Cheers.
What does it look like from above? Looks to me like a toggle fixing like are used in cavity walls. Does the bolt have a cross head on it?
Does that twist at all? Or can you get you hand on the fitting underneath and twist the toggle?
on a second look that toggle won’t rotate I don’t think it will be jammed by toilet body.
Can you get a pair or grips / pliers on that top part to twist
Reply to the thread, titled "Removing a toilet seat" which is posted in DIY Plumbing Advice on Plumbers Forums.
Neathie,
ShaunCorbs,
