I have an inspection cover on my driveway, the cap has cracked and broken, i managed to get it off (unscrew) but now can not find a replacement via the usual outlets. Is there an alternative solution anyone would know about? Or if i need to fit something else would you recommend?
Pipe Diameter is 165mm internal and 180mm external at the top (photo attached). It's about 4m down so anything goes in there it's gone, which is why a replacement screw cap would be my preferred option.
