One plumber I work with insists on upgrading to 22mm on mains pipe at least as far as boiler and kitchen, reckons it improves performance of showers etc when mains fed. And as you say, megaflo needs 22mm.
Thanks gas
This will be going to the boiler. My plumber also suggested 22mm hot upstairs to both showers for that very reason, which I've laid in wait...
I've decided to relocate the stop tap in the garage, couple metres into the house and much easier to get to. Assume no issues in resiting this?
Just need to work out how to turn the outside main off. Found the meter grate with a plastic tap like thing next to it. Seems to just turn on a spindle?
Yes, I was thinking of an accumulator, that would help if someone ran a tap, shower, flushed the loo, or used washing machine at the same time as you were trying to have a shower. Replace 15mm pipes with 22 would ensure no restriction to flow. Worth a try.
Reactions: 1animal1
Fraid not Shaun, not yet anyway... Just got on my sun lounger . I'll post one a week tomorrow 😀
Stop tap currently comes up at side of downstairs waste toilet. So going to run 22mm into garage and mount a tap in there.
Cheers gas, Shaun had previously mentioned accumulator. That's now my primary choice with his recommended boiler, the Vaillant. Especially since seeing the lovely touch screen it comes equipped with.... Will probably save me buying two nest units for my duel circuits
Actually on reflection, I probably can't run duel circuits off the Viessmann (not Valliant)... I presume?
See below for picture of similar valve to mine
Actually on reflection, I probably can't run duel circuits off the Viessmann (not Valliant). I presume?
Just caught the end of this and only read the first page , hi flow combi could be the one instead of the unvented system ,, . 50l stored hot for when 2 outlets being used ,? May of already been said ,. Good luck
Reactions: 1animal1
Dual circuits
And just turn the tap off (like a normal stop tap)
Reactions: 1animal1
I originally looked at hive.. it looks really good. I just think the nest is slightly more pleasing on the eye and more scalable with Google.... Nice tends to play to its own products from what I've seen.
What's your thoughts on them?
Without wanting to start a further thread...
Do you gents happen to know much about hot water loops? In regards to hot water reaching its destination faster and so using less water, wasting less of the cold in the loop that you'd ordinarily use in a normal hot water branch off.
I've done a bit of reading and can see that some countries use this a lot, especially where they suffer droughts. I'm obviously thinking of the hot water wait time, but like the idea of water save too.
As I'm fitting this new water main in the house, terminating at the new boiler site. I'm wondering if I should tap into the downstairs hot water to create a ring - I've already ran a new feed for upstairs - when that gets plumbed into the new boiler, we'll have the option to create a ring.
The reason I ask this is because I have read about some rings that feed the surplus cold water back into the tank for reheating which sounds a bit more complicated than what I am suggesting.
Thoughts?
You mean a secondary return
If it's a big house with a long hot draw off run then yes you need to fit one
Water regs say anything more than 30 seconds is a waste of water and need a secondary return fitting
Thanks Shaun, so that in its basic form is another access point to the ring. Simple as that...
Currently the hot water tank is located on the first floor, therefore there's a simple drop to downstairs and branches to upstairs. Guessing there's no complication in how the ring is formed.
I don't think the house is that big tbf. It's a medium sized 4 bed... But seeing as I'll have access to the pipework, figure it's worth hitting
Thanks Shaun.... That diagram is for vented, do i defo need the bronze pump on boiler/accumulator or unvented set ups?
Scott, I'm using speedfit on copper.... Are you saying that's not suitable?
A
  • Question Question
