K
kevrmorris
We are renovating our kitchen this year.
The plan for the floor is:
• to insulate with 100mm Kingspan
• install water underfloor heating
• 50mm screed (with reinforcing fibres)
• Relay the original victorian quarry tiles.
My plan was to simply join the underfloor heating pipes from the central heating pipes that run conveniently near. This seems simple enough but when I see the price of underfloor heating packs, and what they contain, I must be missing something??
I know I need to work out the following (which products and how to fit them):
• How attach the pipe to the Kingspan
• Incorporate a thermostat
• Type of 15mm underfloor heating pipe to use and is it compatible with HEP system?
But feel that it must be possible to do a good job on a budget?
We fitted a new Vaillant Ecotec Pro 28 and HEP central heating pipes when we moved in 3 years ago. The area in the kitchen that needs heating is 5square meters.
Advice would be much appreciateted!
Cheers in advance
Kev
If the water actually circulates around the floor it will get too hot.
You need a pump just for the floor circuit and thermostatic control over the floor water temperature.
That's what your missing..
I would get someone in to do it for you. The problem with under floor heating is if you mess it up your whole floor has to come up.
It needs to have a blending valve pump and manifold otherwise as snowhead said the floor will get too hot. I went on a course and they said about somebody cooked their cat on the floor by accident as it got too hot.
Also the last time I fitted under floor heating I needed a minimum of 75mm screed on top to get an even heat across the floor. That could of just been the manufacturer that I used or I could be wrong as it was about 4 years ago but I would make sure you have it right.
Done right under floor is great but costs quite a bit done wrong underfloor is useless and costs a fortune.
Cheers for the advice so far. Take a look at the attached image. This if from a ufh kit selling online. Its obviously a lot simpler than most kits. It was this that led me to believe that ufh can be done in a fairly simple way.
P.S. How come I cant post links on this forum?
i fitted a single room kit for a customer and they are very happy with itbut it wasnt under screed which takes ages to warm up and needs to be used differently
this went on a insulation board with groves in and was tiled over instructions didnt ask for preasuring which i think is for under screed to stop collapse
needless to say it was tested before tiles went down
UFH is a very simple system, its a continuous piece of pipe in the floor with water flowing through it. The difficulty comes with making it work with your existing system, and floor coverings screed, tiles, laminate etc, which is where you will need plumbing knowledge to spec the pump, pipe system etc, as one size doesn't fit all.
As croppie has said, electric UFH may be a better option if you want to do more of the work yourself.
I'll get a plumber in to do it. Not cut any corners so far and under a floor would'nt be the place to start. Any particular brand(s) of ufh come up tops for reliability/ease of use etc?
