i heard that irwin do a very good one
Croppie!!
Seriously, that wouldn't work for what I needed it for, that's why I ended up 'trying' the old bare blade in hand trick. Had an absolute hell of a time. Threw my toys out the pram and told the customer I'd be back Monday. That's how much I needed a bare blade with a good grip.If you'd asked i would have told you to save your money. They are useless whoever makes them. I bought one when i was an apprentice used it once binned it then learned how to make something that works in this job.
Btw 24tpi is no use for fine cutting of copper you need 32.
Buy a junior hacksaw for £1. Take the blade out and bend the front leg out a couple of inches then saw the leg just after the bend and cut a draft in it. Bend the back leg back a bit to suit a 6" blade. You need to bend it enough so the blade sits in really tight and it should be quite hard to fit a new one.
You will have something like this which will cut a pipe in a 1/2" space and won't fall to bits using it.
If you are cutting any type of pipe up to 32mm and can get a 10mm gap that will cut it. Believe me.
Hammer.
Then blame the custard for employing stupid kitchen fitters in the first place!
I spent more time dismantling and rebuilding a cupboard built round a boiler today than I did replacing and settingup the gas valve.
And THEN I had to drive on to Londonderry to take the keys back and get paperwork signed!
Beertime!
would this be any good?? It is a Boa Versa saw, the blade is attached at hand, and slides out the front when you push the handle forward, and a spring returns the handle back??![]()
Hmmm, quite possibly. Cheers.
My old man got me one, best part of 9 yrs ago, I think I only have used it once, reading this thread, made me go and find it in the shed to see if I still had it. I used it on removing a set of mono sink mixers where the tails were to close to get a slice on, did the job nicely.
Multitool.
Anyone got a link to this particular multi tool you're all raving about?
Reply to the thread, titled "Review: Irwin Mini Hacksaw 24Tpi 12" (250mm)" which is posted in UK Plumbers Forums on Plumbers Forums.
