Rhino boiler component ID
View the thread, titled "Rhino boiler component ID" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Could anyone please assist in identifying the boiler component on the attached photo?
The boiler is a Rhino Combi
Thanks for your input guys - SimonG you are correct it’s this exact pressure valve pictured on this manual. Which is strange as this is from a Grant boiler manual. Still can’t seam to locate the part anywhere though. Any ideas where I would get this.
That style of pressure switch is a dated design more commonly seen in commercial use.
The one fitted is probably ALCO.
This is probably the modern equivalent you need.
I lost track of it but when searching I found a link stating universal Low pressure switch, supplied with adapter to fit most boilers.
Disclaimer, check suitablity for specific boiler.
Thank a lot for your reply, much appreciated.
Only recognised it because replaced loads on Grant's when the whole unit was plastic and would snap off.
Luckily if I didn't have one on the van one of the plugs in a Dan foss oil pump is the same thread so I can get the boiler away until I can get the bit.
Reply to the thread, titled "Rhino boiler component ID" which is posted in Boiler Advice Forum on Plumbers Forums.
Andy15,
SimonG,
