Roca Toilet Not Filling Fix
View the thread, titled "Roca Toilet Not Filling Fix" which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
GSimon850
Hello all
I am not a plumber but I have managed to fix my toilet with some pointers from this site.
So here is what I did to fix my ceramic throne.
First of all the problem, the toilet would not fill up after flushing. So here is what I did very simple.
In the Roca toilet there is a float value with an actuator arm on the top that opens a valve, and lets the water in to fill the cistern simple yes. No mine stop filling so after much hunting for parts I found a replacement £17.00.
Looking at the picture I could see that this little device could be striped down.
So off with the lid and I managed to strip the little bugger down and clean it with a tooth brush and it works again fine flush, after flush, after flush.
What was the problem it was the rubber there’s a little pin and it was covered in lime scale. I cleaned it and all now works fine after a good wash in hot water.
How to strip it, First run you hand down the pipe and there is a collar pull it up, the pipe will now separate from the main cistern.
You should now have the top halve in your hand with the float bowl remove the black cap cover it pulls off with a little care. When this is off pull up the two little white arms and twist the whole arm anti clock wise at the same time pulling up.
This will now exposed the rubber and pin clean it in hot water and put back together.
Flush your toilet and it should now fill up fine, if not get yourself £17.00 😀
you paid £17 for a fluid master????????????????????????????,they seen you coming,seriously though well done striping it down and cleaning this is a very reliable ball valve but i pay £9
Yep £9 in screwfix/plumbfix with a brass shank as well. They are excellent and easy to work on.
No I did not pay anything but thanks for the tip £9.00.
hi have just purchased a new roca toilet and cannot get the cistern to fill properly any ideas?
carol
is your w/c water supply mains or tank fed?
if its tank fed you may find that the w/c inlet valve requires the high pressure seat changing for a low pressure one. also there may be a filter that is restricting the flow, this is often located just in the bottom end of the inlet valve, that your supply pipe connects to.
Reply to the thread, titled "Roca Toilet Not Filling Fix" which is posted in Boiler Advice Forum on Plumbers Forums.
GSimon850,
carol.james3,
