K
khill
I have a Rothernberger powerfusher for sale
I brought this about 4 years ago and have
probably only used it a handful of times, it
comes with all the hoses and the fittings that
allow you to put it between the pump unions.
The unit has been sitting in the back of my
van so has got scratches on it, but all work
perfectly well. One of the fittings on the top
has been repaired due to a little crack, but
again no leaks, I guess you could get a new
fitting from Rothernberger if you wanted.
Below is the spec of the machine and a
link to the owners manual so you know
what you are getting.
I am looking for £250 ono. collection only
due to size and weight, collection
Cannock, Staffordshire
You can contact me on 07960 687816
or email [email protected]
Only selling as no longer required and
taking up space in van
[DLMURL]http://www.hireguidesolutions.co.uk/Clients/RO-PRO-FLUSH.gif[/DLMURL]
Rothenberger Rocal Power Flusher
Rocal power flusher is designed for the efficient removal of limescale and sludge from heating systems and boilers by circulating water and flushing chemicals at high velocity, then purging the dirty water from the system with a high flow of water.
  • The whole house power flusher will clean a system of up to 20 radiators without removal from the system.
  • Fitted with single fill up valve and double pump valves, allowing you to purge on both forward and reverse flow when operating.
  • With the introduction of the condensing boiler in 2005, the Rocal power flusher becomes an essential part of a heating engineer's equipment.
  • The powerful 0.45hp pump will pump to a maximum head of 15 metres at a rate of 50 litres per minute.
  • The tank has a capacity of 24 litres and can be operated to a maximum temperature of 50 degrees C.
  • Rocal may be used with any commercially available chemicals, except strong acidic or alkali based products.
Includes:
  • 18 metre length of hose.
  • 8 x 3/4in female brass connections.
  • 8 x jubilee clips.
  • 2 x plastic elbows Male 3/4in - Male 3/4in.
  • 2 x Female 3/4in - Male 11/2in connections.
  • Full operating instructions.
  • 240v power supply only.
Had a good old clean out of the garage today and found all sorts of goodies
This is the link to the powerfusher that is now listed on ebay, which has some
pictures for you all to see;
Rothernberger Power Flusher on eBay (end time 02-May-11 15:53:49 BST)
Please see my other items for what else I found, for example over 1000 plastic
pipe clips, plastic pipe covering/boxing, over 100 plastic waste fittings pushfit
and pipe. There are also some flue 45 degree bends and associated items.
Like I have said take a look at my other items to see full listings.
My garage looks pretty tidy for the time being.....lol
