M
mickqc
fitting salamander pump ct50 in the next few days.
the cylinder i`m taking the hot supply from has a top outlet but straight after the 3/4 iron it bends 90 deg.
should i change this pipework to go straight up for a bit and fit an s flange.
Also are s flanges worth the extra expense.
I`m also twinning the tanks in the attic but room is very tight and the new tank can only fit next to the old in an L shaped style. When i connect together with 28mm can i coonect into the side as apposed to the front or back.
thanks for help.
thanks for help.
