View the thread, titled "S plan re-wire price?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
TFGplumbing
Whats the going rate for a total re-wire of an S-plan with an unvented cylinder labour wise?
Good lord no.. I'am not getting some arsehole spark to do it.
Rewire an existing 3 hours so about 100-150 depending on what materials
From new day - day and a quarter 400 -500
When you say total rewire are you talking about running new cables to programmer, room stats etc etc, or just the wiring centre?
If all the cables have been run to the wiring centre, connecting up the S-plan takes minutes.
3 hours, seriously?
Yes
Strip out and test old cables and components 30-45 mins
Re wire cylinder stat and pump 25-30 mins
Dress and cut back valve cables/ strip new ends etc 10 mins
Wire everything up 1-1.25 hours
Yes
Fair enough...
To move programmer to airing cupboard.
To install new programmer.
To install wiring center in airing cupboard.
To install wireless room thermostat for central heating control.
To install replacement HW zone valve.
To install replacement CH zone valve.
To wire boiler correctly.
To drain system.
To install replacement automatic air vent.
To add inhibitor to system
To re-commission & check for correct operation.
To set up suitable hot water & heating program(for prolonged efficient operation)
Existing is a total F*** up
To drain system.
2 days maybe you could get it done in a day and a half but you seen what needs doing go with your gut
why you no use wiring center, what happened to the switch?
Really... really?
Oh its a 24I system btw
Seem hell of a lot worse.
I hate it when you see a programmer on a patress box because you know it's going to be spaghetti junction behind.
Had a nightmare system this week. Instead of one wiring centre there were 3 seperate wiring messes on a Y-plan system.
Boiler kept clicking when central heating was switched off. Turns out someone had wired in the pump live from the boiler and the pump neutral from the programmer. Boiler didn't like that and a relay on the PCB kept clicking as though it was sticking. Putting the line and neutral for the pump into the same box sorted it.
Very weird and was scratching my head for ages. Was about to rewire it too!
Sometimes I find it quicker to rewire them than try to fault find.
Reply to the thread, titled "S plan re-wire price?" which is posted in UK Plumbers Forums on Plumbers Forums.
