davegk80
Hi Everyone,
Hope you can help.
I have a Santon Premier Plus System Fit. It was great until late last year when one of the expansion vessels fell off the wall because it filled up with water. The plumber came round and said he pressurised the vessel again and fixed it back on the wall (could not say why this happened though). Ever since it has been doing the following:
The pressure gauge on the system hangs just below 1bar when the boiler is not on. once the CH comes on this goes to 3bar.
The boiler does not always kick in when the timer says so ie its set for 6:30am at 23c and it doesn't come on. Only when I turn the temp up to 26c will it start.
Before the vessel incident, we did not have to have the temperature up so high to heat the house. 22c would have been plenty warm enough for us but now we have been wacking it up 24-26c and we still feel a bit cold.
The plumber came again today and said that the pressure was too high. When he left he said it should all be ok now. I went upstairs to check when he'd gone and the pressure gauge was at 0 bar?? It did rise to just under 1 bar when the boiler came on.
We have a Danfoss TP9000 in the airing cupboard with the Santon and a remote sensor in the downstairs hall.
Let me know if you need any more info to help me.
I hope you can help with some advice.
Regards
Dave
Hi Everyone,
I hope you can help with some advice as we don't want to go through extra expense with another plumber who seems to not know what he's doing.
Regards
Dave
with that comment in mind its a bit of a cheek to ask for help, but your expansion vessel needs checking out and the failure to fire up could be to do with that issue. santon rm stats arent the best and it could be interference issues on the freq used.
Thanks very much Lame Plumber, it did happen a couple of years ago as well and another plumber replaced the expansion vessel and all was fine (until it fell off the wall again 2 years later!). I'll get them to look into it. By interference on the RM do you mean from things like power cables, other pipes etc?
Apologies, didn't mean any offence with the last comment just feeling a bit annoyed that the same plumber has visited 3 times and still hasn't fixed it. Anyway I have removed that last comment.
Thanks once again.
sounds like a seperate issue to me, maybe air in system i.e.
if it was me i would drain down and refill, test expansion vessel etc.
if your not happy with plumber get another one in.
N
2K
UK Plumbers Forums
Novice needs help
N
