scalding hot new Danfoss c-2 TRV cold lockshield and new radiator only hot at top .
View the thread, titled "scalding hot new Danfoss c-2 TRV cold lockshield and new radiator only hot at top ." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have recently replaced all fourteen Stelrad radiators eight singles four doubles and two chrome towel radiators on small bore 10 mm piping in my four bedroom detached house.The Grundfoss pump is ten years old and sounds good .no bearing rumble.The Ideal classic ff 350 boiler is twenty years old but has been serviced regularly.Even when the balance has been turned down to a quarter of a turn on all the lock shield valves and the problem radiator furthest away has the lockshield fully open and with the pump on speed setting three .the radiator furthest away has a scalding hot Danfoss TRV and the lock shield remains cold.The system has been cleaned with F3 and flushed .The radiator has been removed from the wall and flushed manually and there was no sludge deposits in the radiator .Eventually after about an hour the radiator heats up and the valve lock shield valve is slightly warm.The boiler is set to three.My plumber has agreed to replace the pump with the new grundfoss ups3. In your professional opinion do you think that this will solve wot appears to be a pump problem .I have carried out the usual test of shutting down all the radiators and running the system .The radiator gets scalding hot together with both valves .Many thanks
Fully hot / acceptable?
You either have a balancing problem or pump is weak
Shaun my thoughts exactly .I have tried every balancing trick under the sun same result.My plumber is going to replace the old eleven year old grundfoss with the new ups3 .I wonder if the speeds on this are higher rpms My neighbor has just had one fitted and his is only on speed setting one and he says the rads are getting hotter quicker. Do you know if the latest ups3 is powerfull enough for five /six bedroom house .Maybe thats the one I need .Again many thanks for your expert advice.
I would question speed 1 more like speed 3
Yes I totally agree with you Shaun more like speed three.Just one more question I remember many years ago when we first moved in ,of the fourteen radiators five were upgraded .three singles to doubles but of the same size i.e length and height but two chrome towel radiators in bathrooms from normal size radiators .Does doing this mean that the pump should have been switched from speed two to three its the standard domestic grundfoss super selectric 15/60 130 .Also Shaun I can remember the plumber having to come back every three years approximately and having to flush the boiler as it would be kettling May be the system was under inhibited as I noticed he would only put one bottle of inhibitor in the system. If I had the pump speed to low on setting two as you are always told to set it at that speed Maybe I should have set it to speed three all those years ago .When I eventually have the pump replaced I will let you Know the results.The plumber agreed with me that the system has slowed down in the heating process .It must be the pump Shaun as this circulates the heated water from the boiler.Also Shaun on the non lock shield valves I have all trv valves fully open and control temperature on the room thermostat. I have all the wheel head valves fully open. The three downstairs and one on the landing upstairs take approximately two and a half turns to be fully open but the two wheel head valves on the chrome towel radiators upstairs in the bathrooms are also fully open at five full turns .Have I set the non lock shield valves correctly or am I wrong in having them fully open.
It’s not a ups2 ? It’s older than 10years then
Depends if it’s a sealed system but normally open vent can pump over on speed 3
Sounds like it’s ok maybe turn all the close lockshield valves shut and open them 1/4 a turn then go further away 2/4 etc till your at the furthest away which is fully open
I have opened the lock shield valves as you have said in stepped increments .Still no luck.The top of the rad stays hot but takes ages to get hot all over but only if lockshields are open quarter of a turn on all of them and furthest away lockshield fully open pump on three only if the boiler is on say 5.5 .How about the non lockshield side wheelhead valves I have them fully open
The non lockshield side eg trv side should be fully open eg highest
Yes Shaun they are .I have just set all upstairs and downstairs lockshield to quarter of a turn open and the radiator furthest away lockshield fully open and the rad does get very hot .Not until the boiler is put on the winter running setting of 5.5 as recommended in the ideale ff350 user manual does the lockshield go from luke warm to very hot.I think that this is the best that I can expect from the system.Maybe the radiator upgrade on the small bore 10mm plumbing is at the highest btu rating for the pipe work /boiler or maybe its just always been like it .
10mm isn’t the best they used to say 5m max run
Totally agree with you Shaun I am not a fan of it either. When the system is drained down the ground floor radiators have to be drained individually as they are the piped out of the wall type .My plumber uses a wet vac to do this before flushing rads individually.Many thanks for your expert time and professional advice Shaun thanks for everything
Reply to the thread, titled "scalding hot new Danfoss c-2 TRV cold lockshield and new radiator only hot at top ." which is posted in UK Plumbers Forums on Plumbers Forums.
big john hog,
ShaunCorbs,
