H
Hariseldon
I have a Glo Worm ultimate gas boiler on floor 1 of a four storey townhouse. I believe the heating installation to be original to the house, built in 1997, the system is open ,vented with a header tank in the attic. The pump Grundfos, controller and hot water tank on floor 4. There is a motorised valve allowing separate hot water , heating or combined. There are 5 radiators on the top 3 floors and 3 on floor 1, all using 10mm copper pipe. Larger pipe runs from boiler to airing cupboard and boiler and from pump into bottom of cupboard to go to radiators.
We moved in at the beginning of summer and the system operated fine and servicing had been cared out by a large local firm. All seemed well , although I noted that the radiators on floor 1 were lukewarm at best.
We moved a radiator on floor 4 , partially draining the system. We refilled the header tank, wiping it out. When the heating was put on I found only the top floor (4) had hot radiators, looking at previous posts here I loosened the bleed screw on pump, no indication of any air and tuned all bar 1 radiator off on floor 4, one radiator got hot on floor 3 , turned off the one rad on top floor 4 .
Another rad on floor 3 warmed up ,so turned off the first hot rad on floor 3 and repeated the process down the house till all radiators we're working , including the three previously Luke warm ones on floor 1.
All was well until a month later we had need to move a radiator on floor 1.
The system drained down, was pretty clean no sign of sludge, radiator removed was free of problems , ( not as much water came out as expected initially, but 10 minutes later the rest followed in short bursts! ) *replaced the corrosion inhibitor, turned on the header tank fill again, bled radiators and turned heating on again.
*I was not too surprised that only floor 4 got hot but the previous trick has not worked this time.......I have tried every variation I can think of with radiators turned on and off. ( all radiators on floor 4 turned off did not work and simply caused the boiler overheat protection to trigger)
I believe the pump is fine, as from a cold start all 5 radiators on floor 4 heat equally quickly and within about 2 minutes all are piping hot, I wouldn't have thought thermal circulation could do that as quickly and evenly, there is no one radiator heating up first.
Any ideas, I presume there is some firm of air lock......I am not very confident of previous heating engineer, reluctant to take pot luck with yellow pages.
There is probably a simple solution but I am struggling and the weather gets colder !*
