Its been quite a while since i fitted a boiler so havent checked the latest ,manufs insts but thinking about the annular space around the flue duct as it passes through the core drill hole,it only seems like sound practice to me to seal it inside and out often with expanding foam. Why do so many people just fit the inner and outer flex covers and if you find one with just the flex covers would you issue a notice? If so,what? Clearly if there is a draught and obvious signs of poc re-entry thats a much more clearly defined case than one which is apparently sealed adequately with just the covers
