A
andrewstokes87
Hi again,
Sorry for seeming a bit daft but I just want to make sure I do everything 100% correct. I am currently in the process of completing 5 flats. They all of course have an AECV and my issue is with just 1 of them. The builder has boxed around one of the valves in a flat and has cut out a panel which is screwed in place as access to this valve which they say is ok? But I was thinking as this is an emergency valve it needs to be accessed easily and therefore being screwed shut would be awkward to get to in an emergency! I have suggested to them that they get a hinged door fitted to it so that it can be opened with no hassle. The question I have is wether the builders idea is adequate or am I right for my suggestion?
Question number 2 lol, The builders are down for patching and making good brickwork, whenever I carry out my own work I match up and seal around the flue with gobbo before fitting the rubber seal supplied with the flue. The builders on this job though are saying that just the rubber supplied with the flue is fine and that if that is fitted over the hole then there is no need to gobbo around the flue as they never have on another job. So could you please also tell me if the are correct or not?
Sorry for seeming dumb its just inexperience which I am trying my best to put right I don't want to make any mistakes.
