View the thread, titled "Self cutting DOC - good idea or another bit of junk for the toolbox?" which is posted in Plumbing Tools on UK Plumbers Forums.
R
Ray Stafford
Saw this today for the first time. Apparently we have been selling them for ages! 🙂 I had never seen it before.
Its a cross between a self-cutting tap and a DOC. The idea is that it is a temporary fix to allow you to drain down when there are no DOCs fitted - once drained you take it out, replace the bit of pipe that you have cut into, and fit a proper DOC so that the next plumber doesn't have the same problem.
Clever idea, or just another gadget that will haunt the van?
Unhappy with the product, well I mean I didn't get the packet of sweets when I travelled and picked mine
up yesterday !
Looks a good product tho! I can guarantee I wont need to use it for months , so looks like a very good lucky charm to have in the tool bag.
Kev.
Thanks Ray.
I've mentioned how handy these things can be in the plumbing tips section. Handy, Though I have punched through a hole and lost the copper disc in the past. So perhaps practise it on a cut section of pipe?
I will buy one in 22mm (they are available on the net). Handy to divert a mains, and to check a frozen pipe plug has formed.
hi ray used the drain off today on a flat that had no drain points .was very inpressed - there was a little drible of water when the drain off is screwed in to cut the pipe but not much once fully cut it seals well. the device worked realy well - the hole in the cutter a little small which makes draining down a little longer but not much.was able to then to cut out the hole and fit a tee and normal drainoff for future.i all we need now is a 22m version.great little piece of kit
many thanks ant
I want one of the 22mm ones, a nice way to cut into a pipe that you hope is isolated with your freezing equipment but can't be sure.
My current method is to drill a 6mm hole. If it's still live, put a screw with a few turns of PTFE into the hole. But the above would be better.
any update in these 22mm doc's? was desperate for one today.
Hi Dan
We now have the 22mm adaptor in stock now - although you also need the 15mm complete gadget - the 22mm bit is just the pipe clamp part. Try asking at your local independent, or drop me a PM with a phone number and we can sort something out.
Ray
Reply to the thread, titled "Self cutting DOC - good idea or another bit of junk for the toolbox?" which is posted in Plumbing Tools on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Ray Stafford,
Dan Masey,
