servicing adverts £49
View the thread, titled "servicing adverts £49" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
gaspastemania
Keep seeing boiler servincing adverts for £49 advertised in my area .
IMO this cant be done properly a basic gas safety check yes but full service surely cant be possible for this price. If there is someone on here who does gas services for £49 can you explain what you offer for that because you cant be cleaning appliance properly nor chaecking over appliance adequately nor checking working parts nor offering a top up of inhibitor .Here to be proved wrong !!!!
does it say £49 or from £49.
FOr 30 mins work or less then £49 aint a bad way to earn a living.
You could easily advertise this and get 30 customers a week, £1500 a week.
I try and steer clear of servicing etc, but I have to sometimes and charge £60 for a Boiler. This is my local engineers average cost.
Says nothing about from £49 just says gas servicing £49 on the ones i have seen , i did think if its from £49 then pile hidden extras would be added on . To me this just says tt followed by analyser stuck in flue and rattle screwdriver around boiler for 30 mins.
To me these advert says cowboy ripping the public off , to the unaware public this says bargain !!
Be interested if anyone on here who can do a full service for £49 can actually tell me what they do ?
never mind servicing , i was talking to a guy last night who lost a boiler change by several hundred pounds, using the same boiler and clock etc he rekons the guy who got the job is fitting a new boiler fo £85 labour
Its cheap but I wouldnt say ridiculously cheap, there is no real material cost in servicing in general. Obviously the odd appliance may need gasket kits or an icos needs ionisation probes. Say its an old ideal mexico or something, could spend an hour there giving it a good old clean out, doing all the checks etc. All you need is some smoke pellets, matches and maybe some glass rope and you have earnt yourself £49 for an hours work. You may get unlucky and get a backboiler and fire and spend an hour and a half to two hours, but then your next one could be a one year old boiler which needs nothing doing to it.
£49 doesn't seem too cheap to me if you can get several on the same day in your locality.
Even a back boiler/gas fire can be done in an hour unless it's sooted.
If that's the case then you renegotiate the price.
i hear waht your saying fella , but on an inspection we had last year the GSRi asked why we were removing casing , i said cos its a service , he told me no need just fga and then if needed do a strip down (this was a duo-tec24kw) , i asked him how i can justify my price for 10-15 minutes work . this is when it startyed going pear shape and he bombarded me with stupid stuff.
imho 49 is a probe in probe out , bit of banging hear and there and gone. me i wouldnt put my name to anything like that. you pay for what you get
Totally agree with last post (mfgs), and my experiences are just so, more to the point this all depends on what a service is defined as. I would be interested to know what the initial post would charge for the proper service inc inhibitor top-up. I often get folks asking for services, then arrive to find that they actually need a repair:shout:
A service now means, Analyse reading first, if it passes you dont remove the casing. You only remove the casing if it fails and needs investigating. This is why £49 is not as low as you think.
If any of you are still doing an old style service (removing case and cleaning burners etc) then you are not doing it to most companies standards.
This is why you are now probably double the price of many other local companies.
No they may not do as much as you (clean burners etc) but they are doing it to todays required standards, so why do more than you have to, if it means you losing work for it.
You who are taking the casing off and cleaning, are you then taking a second reading?? If not again you are not doing it correctly.
You do the flue analyser firstly, then either you are finished if it passes or you remove the cover to investigate if it faills then do a second one to see if it has passed now.
I always remove the casing, I dont know why you wouldnt??? You could see a small leak which hasnt been visible from the outside yet, signs of damage from a gasket on its way out etc etc all of which could happen with the analyser reading being spot on. What do you do on the Worcesters? They require checking the fan pressure to be checked on every service.
I'm of the old school really.
A boiler service should at least include case off, visual inspection of components, and brushing/vacuuming.
Inhibitor top-up is IMHO nothing to do with a boiler service, it is an extra.
Surely you would follow boiler MI'S ?
clean fan,condense trap , burner etc etc so casing should come off if mi's say so well thats the way i look at it , as already mentioned on earlier post most of the services i get asked to do is because a fault exists . I can understand the £49 if your just analysing and faffing about but imho your ripping cust off .
Agree, I dont know anyone who puts inhibitor in as standard on a boiler service.
Some boiler mi's put it down as recommend on service, besides i have about 500 litres of it nabbed off site in my garage.
I agree yes, taking the casing off could possibly mean you see a small leak etc.
But do you then take a second reading after putting the casing back on??
If not then you are doing it wrong, times are changing and you have to come into line if you want the work.
Yeah you take a second reading after doing anything that could affect combustion. Are you seriously telling me you wont take the case off because you dont want to do a second combustion analysis?
Reply to the thread, titled "servicing adverts £49" which is posted in UK Plumbers Forums on Plumbers Forums.
gaspastemania,
kirkgas,
