Should I Dilute Spirit Of Salts To Descale Combi Plate Hex?
View the thread, titled "Should I Dilute Spirit Of Salts To Descale Combi Plate Hex?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Finally managed to locate a supplier of Spirit Of Salts, and I now have a small bottle of it. I want to remove the limescale from the hw side of my Turbomax's plate heat exchanger. Judging by the luke warm water out of the hot taps, it must be badly scaled.
Anyhow, do I use the S O S neet, or dilute it? If diluting is recommended, what mix? Also, how long should I leave the S O S in the hex?
Any other advice gratefully received. I'm anxious to get the scale out, without damaging the exchanger.
Many thanks.
do it neet
in open air
use gloves and glasses
i leave it 10- 15 mins
flush throughly
IMO S O S is far to strong for the job (alright for cleaning sanitary ware) I would start off with citric acid you can by from chemist shop in power form mix / dissolve in hot water & run through plate (also great for kettles & cheap).
The chances are it will not be blocked on the secondary side anyway but with crap from the primary's.
Dont forget SOS is inhibited hydrochloric acid & should be handled with great care. It should not be diluted or mixed with anything, even water.
read the cosh sheet!.
it reacts with water and can blow in your face violently as well as give noxious fumes so should not be inhaled!!.
Thanks for all your replies. Can I really get a new face on Ebay for £50? Cheaper than surgery, as I ain't no oil painting. :sad:
If it is the primaries blocked with rust particles, will the citric acid clear these. Or, would it need something stronger?
Couple more questions -
If I use citric acid, what mix with water should I make up?
What metal is the plate hex on my Turbomax made of?
I buy it in a small box with two plastic bags & use it for the kettle keep it as strong as poss (try one bag & if not add the other) you will see it bubble as it breaks down scale & it seems to work best if hot, I would make it up in a plastic jug & then poor carefully into the plate until full, moving around a bit to remove air.
Most plate's I have seen, seem to be made from copper which has been plated.
Once again, thanks for your replies.
Chris Watkins>>>>>>>>>>>>>> I have been to the chemist's and got some Citric Acid Monohydrate - for culinary use, in 50 gram bag. Hope this is the right stuff? Will dilute the whole lot in hot water and try my luck.
If the primary side is choked with rust particles, how do you clear/dissolve this - or is the hex scrap?
Reply to the thread, titled "Should I Dilute Spirit Of Salts To Descale Combi Plate Hex?" which is posted in UK Plumbers Forums on Plumbers Forums.
plumbandplumber,
chris watkins,
