The HW performance on my Turbomax is dire. It just about copes in summer, but any other time, you have to run the tap slowly to get anything other than warm water, with the control set to max. It's a hard water area, and boiler's 8 years old. The water temp doesn't alternate between hot and cold, it's just a constant stream of tepid water.
I'm going to whip the plate hex out, but need advice on cleaning it. What's the best solution to use? Spirit of salts has been suggested, but never used this before. Where can you buy it? How do you dilute it, and how long should I leave it in the hex? I believe it's strong stuff, can it do damage? Is there anything else I should consider using.
Any advice appreciated.
