Should I increase extension plumbing to 22mm
View the thread, titled "Should I increase extension plumbing to 22mm" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Ive extended my house and need to run the plumbing, I will tee off from the main house which is 15mm, I'm wondering if it's worth increasing it to 22mm with 15mm tee offs to the outlets, or should I just keep it all 15mm, I'm wanting water pressure and volume to be better if multiple outlets are used. I need to run 2 sinks, electric shower a toilet and outside tap..
The extension is a self contained flat thats part of the house.
Thanks, callum
Cold water yes hot will be fine on 15mm as you haven’t said the source and you would size the accumulator for both properties
Reply to the thread, titled "Should I increase extension plumbing to 22mm" which is posted in UK Plumbers Forums on Plumbers Forums.
Callummc,
ShaunCorbs,
