E
edwardk
I've fitted the waste pipe for the shower and connected it to a flexible grey pipe and then the shower trap.
I was about to fit the shower tray but thought I might need access to the trap and under the shower after fitting.
So I thought I'd ask - what access do I need and what is the next process to get me to the tiling stage!
Here are some pics:
I built some studwork to support the tray as I couldn't sink the shower trap (pipes in way).
I've filled it with some left over insulation to stop any noise.
I've glued ply to the bottom of the shower tray and planed it flush with the shower base so that when I fit the tray and you step in then it will be directly supported by the floor stud work.
I thought about cutting a section of the studwork away directly in front of the shower trap for access. Is this a good idea?
I was going to stick a flexible seal around the edge of the shower tray then slide the tray into place and use some wood glue to glue the studwork to the ply on the bottom of the tray.
When I've done this the tray will be very stuck down so I want to get it all right!
Any advice welcome!
Thanks,
Ed
Here are some pics:
Any advice welcome!
Thanks,
Ed
