Feb 6, 2018
18
Coventry
DIY or Homeowner
We moved to a new house a few months ago and recently the ensuite shower started leaking into the kitchen. My husband had started to take away the sealant and noticed that the shower tray is not flush with the tiles, so that's likely to be where the problem is but obviously need to ensure that's the only area as there two areas of staining on the kitchen ceiling. My Father has told me that you are meant to fit a shower tray and then tile, not the other way around and we will continue to have leaks unless this is rectified. I do not really want to start looking at re-tiling though and was already considering getting an electric shower fitted as currently there's an electric pump in an upstairs cupboard which gives the shower it's water pressure but it's temperamental and sometimes doesn't work. So wondered what your thoughts were of fitting an electric shower and new shower tray and shower doors, I have attached photos of the current shower, pump and enclosure and what I thought of replacing the enclosure with and also having and electric shower fitted, as the suggested enclosure has a low tray (there may be more ultra thin corner trays available?) would the tiles still need to be disc cut and then the tray inserted?
On another note the main bathroom for some reason the previous owners installed a new bathroom without any extraction fan. I have attached a photo of the bathroom and the light fitting and was wondering whether the light fitting can be changed for an extraction light fitting (as we have one in the ensuite) and then it possibly be fitted up to the other extraction and out of the house?
Thanks for the patronising reply when I was just trying to be helpful. Maybe I should have called myself something else rather than Vicdiy to avoid such an unfair comment. I may not be a professional but I have done loads of jobs at my own house and relatives ( for no charge) and they have all been done to a high standard. Tell me what is wrong with checking and replacing sealant every six months when it can leak and cause all sorts of damage. One of my daughter's recently moved into a new house and had a wet patch in the hallway, although the sealant around the shower looked fine this turned out to be the problem,it took me about an hour to rake it out and reseal what is unreal about that!
Hi vic, I was going to say post #23 puts it better but Dave has replied whilst I was away.
Hi again vic, do it right once and it will not require checking every 6 months bud. That was the main stand out point and hence my post.
I really enjoy reading the posts and comments on this forum as I like to pick up knowledge from those that know better. I think in future I will just read and not bother commenting. I was a senior project manager involved in multi million pound projects but I do realise that there is no substitute for hands on practical experience.
