Guest viewing limit reached
Shower Problem
View the thread, titled "Shower Problem" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
stgiles
Hi all,
I have just recently taken a electric shower off the wall so that i can tile behind it. All i have done is disconnect one elbow joint and the electrics.
After putting it back up it has developed a fault. When it's on it works fine but when switched off it's letting water by ( more than a trickle ) and you can here something still running in the unit. I'm pretty sure it's nothing i've done. Can anyone shed some light on this please. It's a Triton electric shower.😕
hi, i have had this problem before TWICE . Once the shower unit had frozen and bust in the house during works been carried out . 2nd and i know this might sound crazy but the shower unit had dryed out and the seals had failed . Hope this helps you reach a solution .
Regards.
Reply to the thread, titled "Shower Problem" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
stgiles,
Blackcatgas,
