Aug 13, 2017
128
19
18
44
London
DIY or Homeowner
I planning on fitting a shower pump and shower valve diverter on my shower room refurb.
I have a gravity fed system (CW from a loft tank and HW from the cylinder)
Previously had an aqualisa digital.
Have done a bit of research and looked on the stuart turner app for different pump selections.
The bit im not sure about is how to work out my head pressure in order to determine if i need a universal, positive or negative pressure pump.....
Ive seen a few vids online where people time how long it takes to get one litre of water from the shower head.
Ive already disconnected my shower head and only have the aqualisa digital unit that needs to be disconnected come out.
Once ive disconnected everything
Can i just measure the output rate from the open outlets for the CW or HW
Im thinking that by not having the shower head attached and also the pipe outlet being at a lower level than where the shower head would result in a higher flow rate so im unsure if this is an accurate way of checking the head pressure.
Any advice appreciated
That is it for these purposes; there will be frictional losses is pipework and elbows etc but for your purpose a simple height calculation will suffice.
For your information, the terms ‘universal’ and ‘negative head’ are interchangeable in this context.
The trend is to use the term universal, as this pump will work in all situations.
The positive head pump is cheaper to buy and has less to go wrong - so I always use this where possible.
Others I know just use a universal pump in all cases as it will always work - lazy? risk averse?
If you are borderline on the specs then go for a universal.
Personally recommend ST Monsoon if you can afford it, they are really good.
Reactions: Serval and rpm
Thanks all for the info and recommendations.
@Ben-gee
Initially I was thinking to just go for a universal as that would cover me for all cases but now i know a bit more i can do enough to to see if i can use a positive which should hopefully be more reliable
Less to go wrong??
If your going to fit a S T monsoon I would not worry too much. Ultra reliable even in the area I live in with water that's described as 'very aggressive'
I've a fair number ive fitted well over 10 year old still going , my own 4.5 hot water boost pump is 15 + years and has never been touched.
