In the midst of a new heating install and was installing flow /returns and a new 22 mm gas run . As im taking the pipework through property i have come into bathroom which is next to the kitchen which is where the boiler is situated.Removed bath panel to take pipes behind bath as easiest route and through [party wall into kitchen . Where i had taken the gas pipe through the party wall i had sleeved as normal then thought whats the point of that sleeve .Where the hot and cold had previously been bought through from kitchen someone had smashed a foot square hole in the party wall.
i was goinf to stick a vent in the bath panel anyway but what is the logic of sleeving through a cavity where someone has demoilished a decent part of it . Am i to patch up this part of the wall so the sleeve would do as it should stopping gas into a cavity??Was thinking expanding foam but wonderdd if that is correct procedure on this occasion
