Small closet sink leaking
View the thread, titled "Small closet sink leaking" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T
Trudy
Can this be fixed without having to buy a new sink?
The leak seems to be coming direcly from the join under the plug hole, its an ordinary one not a pop up. It is crumbling there too and a bit of see through plastic has broken off where the join is.
Will the silver plug hole have to come out to put another back in as I can't see how this can be done without breaking the sink
Hello trudy,
are you refering to the actual basin waste/plug hole as viewed from above the sink?.
where in the uk are you?. we may be able to give you a guide to how much the repair should cost.
No below the sink its above where the plastic pipe screws onto the straight one, its not coming from any of the threads its the main join. The see through plast washer type thing that a bit has broken off of is undernieth some white crumbling stuff. This is an old sink fitted probably 25 years ago but I don't really want to get a new one as I'll have to get a loo to match
seems like you are refering to the underside of the basin waste where it connects to the trap.
this may be covered with boss white that is crumbling.
either way it should be easily repairable.
cost =1 hour plus parts seems likely.
sounds about right to me where are you situated somebody on here would i'm sure help you.
I'm in Nottingham if anyone works around this area?
well there you go, so am i.
i am in carlton and cover most of nottingham.
drop me a private message (click on my name) and i will call you.
martin.
Reply to the thread, titled "Small closet sink leaking" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Trudy,
REDSAW,
