Mar 1, 2020
17
DIY or Homeowner
I have a plumber who is refurbishing my bathroom, he has installed a SmarTap shower that I purchased however the shower is not operating as expected as when the shower is turned on using a 2 dial controller (1.water temp and 2. redirect to showerhead or shower hose) the water comes out of the shower head and hose for a couple of seconds and then stops.
Firstly Iam no plumbing expert (far from it) but I can see the pipe layout in the loft. The hot and cold water feed has T junctions whereby it splits off to the shower unit (inc 90 degree bends) for hot and cold inlets and then continues to a shower pump used for the bath. See attached images of pipe layout, smartap shower details SmarTap - A New Shower Experience - https://smartap-tech.com/
Iam wondering if this setup is causing the shower not to work, I would appreciate any thought from qualified plumbers to help resolve this issue.
Thanks in advance
Just installed a universal pump (negative head) and it all works fine.
Glad you got it working, I have a similar issue, however with a high pressure system off a combi boiler, the app reads 2.2 bar however the water often slows to a dribble.
I'm considering fitting a high pressure hot water tank and pump, it would be good to know if this has a chance of working though as it'll probably cost a lot.
Any thoughts?
  • Question Question
UK Plumbers Forums
Deleted member 126887
