What are your views on this? The issue is fixed but the contractor's attitude to it worries me for the rest of the job and using them in future.
When my new shower was fitted it was either really hot or really cold, the issue was the hot and cold inlets were the "wrong way round" and the fitter hadn't checked it. Luckily they were able to reverse the pipes by getting under the plinth rather than rip the fittings out and start again.
However they've said that they have effecitvely worked for free fixing it because the quote said "fit to existing pipes". Which I suppose is literally true but it was a bit of plastic pipe work to switch them which is "fitting to existing pipes" to a simple customer like me. And it seems absolutely ridiculous for a professional to work to the letter of the quote if it delivers a product which doesn't work.
I'm shocked by all this, wouldn't a fitter check before fitting an entire shower set up? Seems basic to me - run the water out to check, or at least check the shower unit. They claimed they couldn't because they'd put silicone down but really - a shower hose into a bucket of water perhaps?? Or check before silicone?
They also claimed they'd won a court case by arguing they're entitled to rely on previous installations, not sure of context but again, really in this case? I suppose if it's a drainage block way down in the walls yeah but hot and cold is a pretty simple check.
Thoughts? I can't get my head away from this being a pretty basic mistake, am I being horrible?
