Sok it to me ********s!!
View the thread, titled "Sok it to me ********s!!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
well its a decent boiler going in thats a good start,and really theres not much wrong with the install,think your being to harsh on yourself sort that wonky lime thingy out though
Clips!!
tis a good idea to clip both sides of the tf1.
Also clips near to the corners
Especially on the horritontal under the tf1.
looks good.
would be a tip top premier install on eco or one of them schemes!
Lol
I'm trying to be a bit neater on my installs and am willing to see what you all say this time.
Here's something's I think you'll say so ill address them first
Why is?.......
Hot and cold so far apart
Who is hot below the cold
Why is hot leading into a 22mm pipe
Why is line beater crooked
Why is there a diff coloured compression on limbeater
So the answers are
A. To prevent cold being warmed by hot
B. So I didn't have to cross over
C. Customer didn't want to pay for us to put it all in 15mm to bathroom
D. Didn't realise it was to be honest. Seemed fine earlier.
E. Because the 22mm version is £15 in Travis clearance. Throw the 22-15 coupler in the box and use what you have.
how long did it take you!
its easy to prevent the snotters when soldering end feed fittings on the bottom of a tee, elbow or socket
just heat the fitting up, when you see the flux running wipe the joint with a DRY rag, apply a bit more heat clean it again and do it one more time for luck, then just dab your solder on and you will get a perfect nice ring of solder around the bottom of the fitting, with no ugly snot runs down the pipe.
Also heat from the front and load the solder from the back then if you over load it slightly the bigger patch is at the back where it won't be seen, and if you heat from one side and load from the other you know the solder has went all the way round cause you will see it appearing at the front
You need a new heat mat.
You need to tidy your work area.
You need to stop spunking up the walls.
You need to rip that metal pipe stuff out & use plastic, much quicker.
Ahh I found it. I was looking for this pic to show you. Is this what you mean by use plastic. This is in the same house. These pipes feed the rad in conservatory
Other than rest of comments i would advise this:
- try use more bends (looks better, faster and less chance of leaks
- use a god damn spirit level! Your heating return is rising to the boiler slightly (it looks like it is in the picture!)
I would be lose with my torpedo spirit level, heat proof mat (always doubled over for added protection), dont use a wet rag after soldering (u want a dry to buff your fittings, creates a better silver look)
Reply to the thread, titled "Sok it to me ********s!!" which is posted in UK Plumbers Forums on Plumbers Forums.
Kyle87,
TBServices,
